Rear bumper RED/AMBER lens question
Old 02-15-2013, 02:13 PM
AZRover's Avatar
Default Rear bumper RED/AMBER lens question
I recently replaced the rear bumper on my 2000 DII. This isn't the first time I've asked myself this question. There are bulbs in both the red part and amber part of the lens. Now I know the amber is for the turn signal. I have no idea what the red part is for. I have turned on the hazards, that's not it. I have hit the brakes, that's not it. I have turned on the headlights/running lights, that's not it.
Can anyone tell me what they are?
Thank you,
Scott
Old 02-15-2013, 03:10 PM
aarongregor's Avatar
Reverse fog lights. See attached pic. I have an 03 and the button in the pic lit up turns them on.
Attached Thumbnails Rear bumper RED/AMBER lens question-imag0653.jpg
Old 02-15-2013, 03:28 PM
It is called a tail/flasher lamp in the RAVE - see attached. Maybe a wiring problem? But makes sense as a rear fog also. The electrical schematic shows connector C0499, which isn't in the electrical libary.
File Type: pdf
Old 02-15-2013, 03:48 PM
Savannah my XK8 had them as well and called them reverse fog lights. They are brighter than the tail lights.
Old 02-15-2013, 06:40 PM
AZRover's Avatar
Buzz.....so they come on when you activate the switch for the front fog lights located in the lower front bumper?
Same on my Benz. But maybe some Rovers just had it as another tail light, like the D1.
Old 02-15-2013, 07:22 PM
blamo's Avatar
Diff switch than front .
Old 02-16-2013, 11:18 AM
coors's Avatar
My Audi had the rear fog light as well. Actually it only had one bulb on the drivers side. To alert the other motorists in bad weather as to which side to pass you on.
AZ the switch is located on left side cluster under the front fog light switch.
Old 02-16-2013, 01:07 PM
AZ I posted a pic of the switch....
Old 02-16-2013, 11:42 PM
Rover_Hokie's Avatar
Hopefully the rear fogs keep someone from rear-ending you in all the fog in England. I also used them on dusty trails to keep the guy behind me from getting too close in the dust. I took my rear fogs out now, and use mine in the tail light loop, and changed the bulb to match the tail light, so it is not as bright as a brake light as it is from the factory when used as the rear fog. I also, replaced the amber/red with '03/'04 clear/red lens when I broke one of mine. Moved the backup lights to the new clear bumper lights, and put amber bulbs up top and re-routed the turn signals to the upper clear lens, now with amber bulbs, for turn signals. Basically now it functions like an '03/'04 except with added bumper lights now when I have my tail lights on.
I am going to use the rear fog light switch as one of the switches to run my roof lights, when I get them wired up.
Quick Reply: Rear bumper RED/AMBER lens question
