Rear D/S interchangabilty
Old Jun 12, 2011 | 09:21 AM
kenk's Avatar
Default Rear D/S interchangabilty
So, when I was installing my spiffy new fully serviceable front d/s on my '04, I noticed the rear has a roto-flex.
What are the chances the rear d/s and diff flange off my '97 D1 parts car would bolt up?
Old Jun 12, 2011 | 10:43 AM
jafir's Avatar
100% it will bolt up, but the 03 and 04 have a slightly shorter rear drive shaft than 02 and older. I've heard it will work though.
Old Jun 12, 2011 | 10:18 PM
kenk's Avatar
Cool, since the d/s is already off my parts car, if it fits I'll have a couple new u-joints thrown in and swap over. Do you happen to know if the flange will come right off the rear diff or will it require a puller?
Old Jun 13, 2011 | 07:45 AM
You will have to buy a new flange kit to be able to use a D1 shaft, why waste the money, there is sure nothing wrong with the Roto-Flex.
Old Jun 13, 2011 | 09:13 AM
kenk's Avatar
I have no problem with using a rotoflex, I just figured when it does give up, if I had all the parts already to convert it to a two u-joint set up, why not? But, if the flange off my D1 won't work, cost wise would be equal.
Old Jun 13, 2011 | 09:43 AM
jafir's Avatar
No, the d1 flange should work. The diff's are the same from d1 to d2.
bcolins
Jun 22, 2013 08:55 PM
hilltoppersx
Dec 22, 2010 05:15 PM
ljdiscovery
May 22, 2008 10:30 AM
00discosd7
Dec 27, 2007 07:08 PM
01 Discovery
Dec 1, 2006 12:07 AM
