Rear differential fluid... didn't like this...
Old Oct 17, 2010 | 03:03 PM
SDinDS's Avatar
Default Rear differential fluid... didn't like this...
Just finishing up the 60k service. Did the front differential, no problem other than I had to use a 4 foot breaker bar to take off the drain plug. Some metal shavings on the plug. (about 1/8") Came out black. Did the rear. Had to use breaker bar again. At first the fluid came out black, then white creamy crap Also had about 1/4" of metal shavings on the plug. I noticed the rear plug had what looks like teflon tape on the threads but the front plug didn't. I checked the breather hose on the top of the differential and it's connected and not broke anywhere. Not leaking anywhere. Just wondering where water might have got in at? Would this have happened if the PO did a lot of water crossings? No weird noises while driving, even at highway speeds so I don't think any damage is done. But would like to know how it could have got this way.
Eric
Attached Thumbnails Rear differential fluid... didn't like this...-rear_diff.jpg   Rear differential fluid... didn't like this...-rear_diff2.jpg
Old Oct 17, 2010 | 03:16 PM
It has probably never been changed and the breather is clogged and the condensation could not escape.
Refill it with cheap stuff, drive for a couple of weeks and change it again.
Remove the breather and blow through it with your mouth and see if it is clogged.
Old Oct 17, 2010 | 05:21 PM
SDinDS's Avatar
Thanks Spike. I'll check that. I refilled with 85w140 and I'll change that again a few weeks as I'm sure the drain didn't get all the crap out.
Eric
Old Oct 22, 2010 | 04:42 AM
phatduc's Avatar
Try some Redline Shockproof, heavy wt, and that will take care of the metal shavings on the magnet.
________
Motorcycle Tires
NhudeST
Mar 24, 2010 11:13 PM
humroot
Mar 20, 2008 08:29 AM
Lar45
Jan 21, 2008 08:26 PM
wvcox1
Sep 12, 2007 05:25 PM
rebel1
Oct 7, 2005 09:41 PM
