Rear Differential Needs replacement
I have a 2004 DII that I am working on getting all the maintenance items checked off. When replacing the rear differential fluid, I found a piece of a roll pin and a ton of fine metal shavings. Fluid was silver in color and the magnet had an inch of crud on it.
I just need to confirm if all Discovery II rear differentials will interchange. I understand the gear ratio's are all 3.54:1. Is there anything different about the 2003/2004 vs. 2002 and before? In searching EBay I see some ads listing up to 2002. My diff has the 3 bolt holes on the flange.
Thanks
Thanks
All D2 diffs i believe are the same. If you do wish to remove the rotoflex i recommend just changing the flange instead of putting a front diff on, the teeth on the ring and pinion should be directional. If you cannot source one out I have my stock front and rear diffs and would be willing to give to you just not sure of how expensive shipping would be.
BearCatRover
03-14-2016 10:37 AM
