Rear Door disconected and wont open
Old Jul 14, 2016 | 11:59 AM
JoelMoak's Avatar
5th Gear
Default Rear Door disconected and wont open
2000 Discovery II I bought it on Craigslist for a "good deal" however I have found several issues. The rear door will not open and the previos owner in some attempt to open it disconnected the cable from the inside latch. I have managed to peel back the panel inside. I have pulled up the lock and tried to keep it stuck unlocked by wedging it but without that it will drop. I lubricated the outide latch with the logo removed.... Nothing... I used an an angle tool to try and move whatever the cable was moving but havnt been able to move anything that will open the door. I am poised with a drill and a hole saw to destroy the actuator. Any suggestions prior to destruction?
Old Jul 14, 2016 | 01:40 PM
d.a.r.y.l's Avatar
Don't do it. Do you have a Rave manual or CD if so it will help you. This is not the time for Bubba tools. D*
Old Jul 15, 2016 | 11:19 AM
JoelMoak's Avatar
5th Gear
Hmmm, I havn't yet.. I found a local 2000 Disco II with the rear door intact but they will only sell the entire door. An actuator is very expensive but I'm not seeing any way to get the door open.... And I might have to replace the actuator anyway....
Old Jul 16, 2016 | 11:27 AM
JoelMoak's Avatar
5th Gear
I went all "buba" on it... Nothing else worked
Old Jul 19, 2016 | 03:17 PM
squirt's Avatar
Recommend you read this thread.
https://landroverforums.com/forum/di...nt-open-41669/
Have you already removed the interior panel and examined the actuator? You mention peeling it back, but it should be possible to remove it completely...?
Old Jul 19, 2016 | 03:44 PM
JoelMoak's Avatar
5th Gear
After removing it and multiple attemps to open it with a mirror, light and small tools I finally destroyed the actuator to the point where I opened the door. I just recieved my new actuator and should be able to easily install it today... I attempted to post pictures of the door open but did not make it past the moderator...
Old Jul 20, 2016 | 11:41 AM
JoelMoak's Avatar
5th Gear
New actuator showed up. Door now works as intended!
msm15
Apr 1, 2025 09:27 PM
94svt50
Nov 23, 2013 03:46 PM
thomas22
May 6, 2009 09:05 AM
