Rear door grip latch
Old Jun 3, 2013 | 09:09 PM
Colorado David's Avatar
Default Rear door grip latch
I've been dealing with this for a while. My rear door latch handle will actuate but then stick in the open position. I've been carrying a good sized flat blade screw driver to gently pry it back out so I can get the door to latch when I close it. I read somewhere here that you could remove the rear door green oval to clean and lubricate. Now I can't find the reference any more. Has anyone else had this issue? Thanks. I need something else to work on this week. (sarcasm) My radiator comes on Wednesday and I pick up a new dishwasher on Thursday.
Old Jun 3, 2013 | 09:29 PM
captain203's Avatar
Pop the land rover badge out and lube the crap out of it...........Did mine today as it stuck when I opened the rear door.
Old Jun 3, 2013 | 09:39 PM
dpaller's Avatar
mine does this all the time. we use a ton of salt on the roads here in Michigan, always spraying it and still need to reset the handle all the time.
Old Jun 4, 2013 | 11:27 AM
SuperSport's Avatar
How are you going to wire in the Dishwasher? And where will you drain it? Out the Sunroof Overflows?
KGN96discoSE7
Apr 4, 2010 09:05 AM
javoli002
Mar 9, 2009 12:07 AM
CandiMan
Aug 24, 2008 10:35 PM
