rear door speakers not working
Old Aug 7, 2006 | 02:03 PM
bklahl's Avatar
Default rear door speakers not working
Hey everybody,
I have a 96 Disco SE. It has an after market radio I installed. I hooked it up just like the old aftermarket radio that was in there. My rear door speakers do not work. I assume I didn't get them hooked up. Is there any trick to these speakers, or do I need to just keeep fishing around for a loose wire to connect to the radio.
Thanks for any help
Old Aug 8, 2006 | 05:47 AM
xb70valkarye's Avatar
Default RE: rear door speakers not working
The rear door unit is a sub. I am not sure if you knew that or not. If you did, I am sorry, if not try and turn your bass up and see if you notice anything. Hopefully this helps.
Old Aug 8, 2006 | 11:01 PM
Brad S1's Avatar
On some aftermarket head units you need to let it know you've got subs.. I haven't seen the wiring myself, but if it's got a sub in line, then you need to let the head unit know where to output the signal
Old Aug 9, 2006 | 07:36 PM
bklahl's Avatar
Thanks for the info I will try to take it out and find my missing wires
DiscoI
Nov 1, 2019 11:56 AM
troverman
16
May 31, 2019 06:50 PM
ethomp16
Jul 16, 2011 03:09 AM
DooDer
Mar 25, 2011 04:12 PM
slamwhit
Jun 18, 2005 02:13 AM
