Rear door subwoofer EXACT FIT replacement JL Audio 6.5" component woofers
  #21
Old 04-15-2015, 11:45 PM
Joemamma1954's Avatar
Awesome setup. What brand and size are you using. That sub box looks kick ****, makes oem look lame. Did you make a whole new box, or just the front panel, and attach to existing? I wish I had your touch with the woodwork, but you have inspired me to rethink what to do with my rear door. I already wired truck for my monoblock amp and my lo-profile 10" pioneer enclosure. I was going to get the alpines 6.5's and put in doors and rear, but time to rethink.
  #22
Old 04-16-2015, 08:44 AM
cybercop's Avatar
The box is a combination of birch and fiberglass. Was kind of a tricky build. The smaller the box, the more attention to detail you have to make. The making of the grill and mounting of the grill was probably the most challenging part.
After framing the box, start making the grill. I used the cheap stainless steel grill stuff you get from the hardware store to replace your worn out charcoal grill grate and some nylon screen replacement material. This was really hard to route a edge exactly deep enough for this to recess flush
After you build the box frame, just cover with fleece (Delta blankets work great)
Building of the box frame is probably the most technical. The most time consuming (and nasty) was the glassing, sanding, glassing, sanding, glassing, sanding, bondo, sanding, bondo, sanding, bondo primer, sanding, primer, sanding, primer, sanding then texturing and painting the sub box and grill
After texturing and painting
Joemamma1954 (04-16-2015)
  #23
Old 04-16-2015, 03:53 PM
Yoops Racing's Avatar
Damn I would buy one of them from you......you should make more
  #24
Old 04-16-2015, 07:44 PM
cybercop's Avatar
I would have to charge a TON for these. Grant you, I could do the next one in about a quarter of the time, but it would still take a while.
  #25
Old 04-16-2015, 10:49 PM
cimomd's Avatar
Those look excellent, very nice finish and I am sure alot of time and effort applied to detail, bet they sound phenom !!! Getting my 4 doors replaced with the JL 6.5's on Friday or saturday I will update.....
  #26
Old 04-17-2015, 04:19 PM
Dinoco's Avatar
Looking forward to the update!
  #27
Old 04-25-2015, 10:10 AM
Dinoco's Avatar
Please tell me they fit and sound like butter.
  #28
Old 04-25-2015, 09:25 PM
Externet's Avatar
  #29
Old 04-26-2015, 01:28 AM
Originally Posted by Externet
133 5 star rating, 61 1 star rating. I don't know if i would trust them.
  #30
Old 05-02-2015, 10:54 AM
Big Jim Swade's Avatar
I just ordered a set of the JL Audio C2-650 component set from Amazon to replace my rear door woofers. Runs about $149 with shipping and includes the tweeters and separate crossovers.
Quick Reply: Rear door subwoofer EXACT FIT replacement JL Audio 6.5" component woofers
