PSA on rear driveshaft removal - the splines are clocked and if you remove the rear driveshaft from the stub shaft at the e brake the splines ARE clocked and must go back in the exact same position.
Generally I mark up the prop shaft, brake drum, rear flange , on the rotat flex bolt holes, easy to do with a pin punch just a couple of dots next and on the components or a dab of paint
That's usual for all manufacturers. It's also a matter of the joints being lined up with one another so there is no strange resonance. It's not so much sloppiness as it is cost effective manufacturing.
Maybe, but as a guy who has run design and manufacturing engineering for 33 years I would not let one of my engineers design it to be clocked. It is what it is though, just thought I would let folks know.
To expand on the PSA...unless they're aligned, they don't fit back together even if you get impatient and try to finesse them together with a 5lb sledge hammer. Or so I'm told.
