Rear driving lights out
Old Jan 4, 2022 | 06:49 PM
gulfstream69xr7's Avatar
Default Rear driving lights out
03 D2. If I turn on the lights the rear driving lights inside the red housings on the driver's side do not come on. Checked the bulbs by swapping to the other side and they are fine. Known good bulbs in either driver side light socket do not light up. Brake light works. Turn signal works. Just the two sockets in the upper red part of the housing. The larger bulb is the two-filament driving and brake light. The brake light is working, the driving light is not. I don't know if it makes a difference, but both bulbs went in the license plate light as well.
Anyone ever experience this?
Old Jan 6, 2022 | 07:10 AM
adalton's Avatar
Check fuse 33 and 11 underneath the dashboard
Old Jan 9, 2022 | 08:15 PM
That was it.
Thanks!!
Old Mar 10, 2023 | 06:47 AM
dparham's Avatar
ill double check mine but yesterday I checked them all and all had continuity but maybe Ill check to see if there is voltage at that socket on the fuse panel... is it possible its a digital signal from the BCU and its acting up ? mine is only on drivers side USA
dougn
Mar 10, 2023 04:40 PM
rreinholt
Oct 10, 2013 08:47 AM
binvanna
Nov 7, 2012 03:59 PM
jbarr89
Aug 7, 2012 08:38 AM
chrisusvi
Feb 12, 2007 11:32 AM
