Rear end almost touching the ground
So my drive shaft went out the other day. My wife was driving in the neighborhood and it went, did not damage anything from what I could see, couple dings underneath, nothing maj. So, the truck has been sitting in the garage, doing some other work up front. I noticed tonight that the back end is almost on the ground! I figure it's the air suspension but not sure what caused this while sitting in the garage. I did disconect the battery while working on it? Or, could the shaft have hit something that I did not see that would have affected the suspension??
Thanks for any ideas,
mine leaks down every night. It's not that big of a problem right now, it airs back up in just a minute..first bump out of the driveway is a rough one though. Start saving up for a coil conversion, I'm going to lift mine anyways so that will be a good time to do it.
also, search on here..a guy just posted an update to a cheap air bag fix.
Thanks for the answer I was hoping for Mike!! Both sides are even, was hoping just electrical from disconecting the battery. This would have been the last thing I needed this week......putting in new drive shaft and doing head gasket, valley gasket, heater plate gasket, new plugs/wires (8mm Magnecor), on & on.
Thanks again!
Thanks again!
RROJ
07-24-2011 07:59 AM
kcirtap
09-26-2007 09:39 AM
