Rear end clearance questions
Old May 4, 2009 | 07:00 PM
malmberg's Avatar
Here are some pics. This is with a little less than 1/4 tank of gas and the rear cargo empty.
Attached Thumbnails Rear end clearance questions-uneven-rover-001.jpg   Rear end clearance questions-uneven-rover-004.jpg   Rear end clearance questions-uneven-rover-008.jpg
Old May 4, 2009 | 07:43 PM
Jupiter Rover's Avatar
You can put some small spacers in the back.
Old May 5, 2009 | 09:45 AM
Originally Posted by malmberg
Aftermarket bumpers are definately on the list. The front bumper already had a couple of cracks by the headlight washers so the missing chunk is no big deal. I also want a steel bumper for the back since that one was broken when someone rear ended me. I was thinking that even after the front bumper swap that the rear would still be lower than the front. I am estimating that the bumper will drop the front about an 1/2 inch but it would still be unlevel. Plus I am not sure when I will be able to afford the bumpers so I want to make it level. I was told the 751s were the springs to get from this forum and I do like the way that they feel. I just want to make the rear the same without rigging it.
So here is my truck with 751's in the front. 751 are essential for winch bumper trucks and yes, can be a little firm without all the front weight.
You may want to consider 779's for the front, just beware that if you do play hard and or load the front end tthe 779's may sag with time.
Old May 5, 2009 | 09:49 AM
By your pictures, your truck is very close to level, if you want to bring up the rear up a little, put 2 isolators on each rear spring and you'l be set.
Old May 5, 2009 | 11:12 AM
jycsalas's Avatar
I agree with Mike, It is VERY level. If you just go off by the distance of the space between the top of the tires and the wheel arches then you will think the rear is lower. And if you look at the direction of all your horizontal lines above the green center line (roof gutter, base line of all the windows, side molding) they get closer to the green line as you get further front. mine is the same way before and after my 2 inch spacer install..(which i don't recommend) lol
Old May 5, 2009 | 02:04 PM
jeffrudy's Avatar
isolators will do it or a 1" spacer, nice looking disco though i think Ive seen you driving around my neck of the woods here in Joshua / yucca we are trying to get a little rover expedition going if you'd like to join in send me a PM and spread the word
JJ
Nov 4, 2008 10:47 AM
Disco2Guy
Sep 26, 2008 12:33 PM
HanselRox
Sep 24, 2008 04:00 PM
freeranger
Mar 29, 2005 06:03 PM
