Rear end sway/loose...annoyed.
Old Feb 12, 2013 | 05:27 PM
AdrenalinPlease's Avatar
Default Rear end sway/loose...annoyed.
I've notices the rear end being a bit loose but never payed it much mind. Now after uninstalled the suspenders it is way more present. I did the alignment to perfect. One thing off was the right rear toe, there is no adjustment there...it's as if the axle itself is crooked but only on the right side??? Wtf is thy possible?
Anyway the reason I started the thread is when I am hard on the brakes the whole truck sways and is difficult to keep straight (even before suspenders). When I am on a not so perfect road the whole truck sways as if it steers itself slightly and I have to correct a lot. I checked everything out in the back and it seems tight and legit...what?
Lastly there is a clunk in the back during articulation mostly from the left rear and it has now turned into a hollow thump and is present when going over rough terrain.
Help?
Old Feb 13, 2013 | 07:49 AM
What year and how many miles on it? If you are still running the stock suspension, it can get real sloppy with the sway bars unhooked.
Old Feb 13, 2013 | 08:52 AM
04 105k with TF 3" lift (are you not following my threads??? or my pms? hehe)
Sway bars are not unhooked.
Old Feb 13, 2013 | 09:30 AM
Catch some, miss some and sleep in between.
Might check the watts linkage and both front and rear arm bushing, all 12 of them for sloppiness.
Old Feb 13, 2013 | 11:39 AM
Ill check watts linkage, how do I check watts linkage?
By arm bushings do you mean the long *** arms that run to the axles?
Old Feb 13, 2013 | 01:07 PM
jafir's Avatar
search...
https://landroverforums.com/forum/di...g-video-55727/
Old Feb 13, 2013 | 02:53 PM
Thank you good sir!!! I will get on that immediately!!!!
deer4011
Jan 12, 2021 07:10 AM
JPSpen
Oct 12, 2012 03:15 PM
timdunbar
Aug 25, 2010 09:07 PM
robot808
Nov 18, 2009 11:10 PM
Speed racer
Nov 11, 2009 09:44 AM
