Loose front end?
Old Aug 25, 2010 | 05:09 PM
timdunbar's Avatar
Default Loose front end?
When I go over a bump it feels like something in my front end is loose. I jacked the truck up and tried to wiggle tires front back back and then top to bottom everything is solid. Also when I hit a bump at speed my steering wheel wants to wobble back and forth. All bolts are tight everything looks good and solid. I am thinking front shocks at this point. Any other ideas?
Old Aug 25, 2010 | 05:39 PM
sloan74's Avatar
How about just normal driving at high speeds?
It might just need an alignment maybe?
I had steering wheel wobble when I purchased my 99. Alignment and tire balance at Firestone fixed it right up. Worth every penny....mainly because I cannot do it myself LOL
________
VX800
Old Aug 25, 2010 | 05:48 PM
timdunbar's Avatar
Drives straight and true nothing loose, steering wheel stays centered.
Old Aug 25, 2010 | 06:22 PM
What is the tire psi in the front?
Old Aug 25, 2010 | 07:16 PM
timdunbar's Avatar
30 psi in both front, 30 psi in driver side rear as well and 40 psi in passenger side rear, going to go remedy this now.
Old Aug 25, 2010 | 07:30 PM
timdunbar's Avatar
ok now as per manual 30 psi front 40 psi rear.
Old Aug 25, 2010 | 09:07 PM
lipadj46's Avatar
Are your amigos on? Could be a bad hub, leaky PAS pup, ball joints, steering tie rod end, broken spring, stuck caliper etc.
Could be worse could be a loose rear end.
AdrenalinPlease
Feb 13, 2013 02:53 PM
Stuart Cruickshanks
Dec 27, 2012 03:05 PM
arains44
Dec 17, 2012 08:59 AM
Baylink
Oct 10, 2010 08:09 PM
robot808
Nov 18, 2009 11:10 PM
