Rear fuel door piston actuator
Old Jan 11, 2012 | 11:38 AM
airmarc's Avatar
4wd High
Default Rear fuel door piston actuator
Is there a way to lubricate this mechanism? When I press the button to open the fuel door, the acutator makes a loud noise like the piston or something inside needs lubrication.
How do i access it?
Many thanks,
Marc
2004 Disco SE
Old Jan 11, 2012 | 12:01 PM
tee51397's Avatar
Remove the lower right rear cargo area trim pieces, it's bolted to the inner body frame with three nuts, (I think 8MM socket, maybe 10mm). A new one is cheap, right at the $55 mark and part number FUG100580. They do normally make noise though, even brand new out of the box. Won't even attempt to describe the normal sound but noise is normal.
expedio2005
Oct 4, 2019 01:57 PM
vic_lagina
Aug 6, 2015 06:54 AM
roverroveroverthere
Apr 23, 2012 10:22 AM
