Rear Hub Axle Housing BROKEN BEARING SHAFT RUB
Old Aug 11, 2018 | 05:34 PM
swandrum1's Avatar
4th Gear
Default Rear Hub Axle Housing BROKEN BEARING SHAFT RUB
ANY THOUGHTS?? ANYONE.. I am new to this forum.. thanks all.. Dam i love my Discovery 2 but last owner drove it with a destroyed bearing
Attached Thumbnails Rear Hub Axle Housing BROKEN BEARING SHAFT RUB-rsz_rover_bike_stuff_153.jpg
Old Aug 11, 2018 | 06:54 PM
I almost wonder if you could smooth it out put in the new assembly and it would hold?
Old Aug 11, 2018 | 07:13 PM
Best4x4's Avatar
Ouch!! Yeah I second that, or having someone weld in some new metal & you’d have to then file it down smooth.
Old Aug 11, 2018 | 07:48 PM
Sixpack577's Avatar
I would buy a junkyard axle and swap it in.
Old Aug 11, 2018 | 09:45 PM
This is probably the best idea
Old Aug 12, 2018 | 05:06 AM
The Deputy's Avatar
That's the portion of the axle housing, where the hub o-ring seal against. Having it welded and machined would probably exceed the replacement cost (junkyard). And, l don't believe you could weld and hand grind it into shape...it would have to be absolutely perfect...since the o-ring rest against this recessed area.
Brian.
Old Aug 12, 2018 | 08:26 AM
Best4x4's Avatar
If you knew someone that welded = would be an option (down in my neck of the woods 80% of the men around here are pipe fitters/welders), but yeah I agree grabbing a junk yard axle would probably be cheaper/quicker. As far as the O-Ring is concerned I’ve worked on several D2’s that didn’t even have O-Rings installed. Someone had just slapped some black/grey RTV in there instead & they weren’t leaking a drop before I removed the Hub assembly.
Old Aug 12, 2018 | 08:36 AM
swandrum1's Avatar
4th Gear
Brian.
how long do you think it will last as is?
Old Aug 12, 2018 | 08:50 AM
swandrum1's Avatar
4th Gear
Brian.
how long do you think it will last as is? With a new hub and axle
Old Aug 12, 2018 | 08:52 AM
Best4x4's Avatar
I dunno that is putting a decent amount of stress on a new hub bearing for sure as is.
The weld (basically just a blob to add more metal in that spot) and some RTV I think would be the poor mans way out. Once the new metal/weld was in place I’d just use a small grinder on it until the new hub went in easy, then I’d slap on some RTV & see what happens. It certainly isn’t going to be as bad as it was to start with. The RTV should fill any gaps vs the O-Ring. Was it leaking diff fluid before this was discovered?
Regret1990
LR2
Nov 19, 2018 08:32 AM
swandrum1
Aug 12, 2018 04:58 AM
nickm347
Dec 6, 2016 11:08 AM
AK Rover
Jul 11, 2010 08:57 PM
waynehicks
Aug 2, 2009 10:36 PM
