Disable SAI 2004
Old Aug 11, 2018 | 12:59 PM
Llamasayswhat's Avatar
Default Disable SAI 2004
I'm in the midst of my headgasket job on my new-to-me 2004 disco, and the passenger side SAI metal pipe assembly going in to the head twisted up and mangled itself on removal. I have access to Autologic, is there a way to disable SAI through it? is my only option replacing the ECU with a non-SAI ECU? Any ideas on cost to replace that pipe? I have not yet looked
Old Aug 11, 2018 | 04:13 PM
zuke's Avatar
No disabling it as it is hardwired in. Your choices are
1 . Get a new tube
2. Delete your sai and clear your code once a week
3. Delete your sai and find a matched set of ecu, bcu, gauge cluster from a non said and swap in
I
Old Aug 11, 2018 | 06:16 PM
No Doubt's Avatar
Someone welded the SAI bolts shut and removed the SAI pipes on my Disco 2 andthe motor runs just fine. It will throw an SAI code every now and again, but that's meaningless.
Old Aug 11, 2018 | 09:25 PM
zuke's Avatar
I jb welded some nickles under the brass caps
Old Aug 11, 2018 | 10:14 PM
Alex_M's Avatar
I did this. Also pulled the cluster and put some tape over the back of the service engine light. Nobody else will likely ever own this truck, so no issue.
Old Aug 12, 2018 | 07:25 AM
Unless he lives in an area that does emissions testing
Old Aug 12, 2018 | 08:20 AM
Red5's Avatar
Brand new pipe assembly is around $200. Here is a used unit for $75
SAI Pipe
Old Aug 12, 2018 | 08:49 AM
zuke's Avatar
Default State emissions test
I don't see how this would show up on a state emissions test .they poke a rod in the tailpipe. How would that pick up the sai being bypassed?
Old Aug 12, 2018 | 09:05 AM
Saturnine's Avatar
Visual inspection plus they usually plug into the obd port so the computer will know what the car engine is etc.
Old Aug 12, 2018 | 09:36 AM
Best4x4's Avatar
Yeah in TX if you live in an OBDII county if any of the OEM equipment is bypassed, if there is a pending fault present, CEL light, or it fails the probe test = fails. They also have to have like 2-3 ready status.
SAI isn’t a big deal, I’d personally replace the pipe & move on if it wasn’t giving you issues before.
I live where they just look at the wiper blades, the head lights, and “maybe” the ebrake and send you on your way lol. Explains the crap I see out on the roads for sure!
2Guinness
Oct 3, 2018 05:52 PM
zuke
Apr 23, 2018 09:33 PM
Hephaestus
Feb 28, 2017 07:58 PM
shonuff93
Jun 5, 2012 05:09 PM
ajh
Nov 5, 2007 02:12 PM
