Rear hub nut
on
Hub Nut
I did all four on my 97 DI. All four are the same, I bought the adapter from Rover's North, it fits and works well, but there is no way to use it with a torque wrench.
If you already have a large socket you used on the front, you are set.
I think AB also has the same adapter as RN, don't remember the price.
on
One thing I was not aware of when I did my first set, the rear grease seals that go behind the bearings. I had to reuse mine, but they were in good shape as were my bearings. I had purchased a new set of bearings, but originals were in great shape , so I cleaned them good and repacked with good grade of synthetic waterproof bearing grease using Saram Wrap loaded with a big glob of the bearing grease to pack in the cleaned bearing, This helps minimize the grease getting all over you.
I read later there is a double lipped real seal available that is supposed to be better than the stndard one. I think it came stock on the defender possibly?
My front bearinsg were still good as well, so I have an extra set of bearings for the spare parts kit I am building up. Never know when you may need a wheel bearing out on the trail or road. I also have spare lock washers and seals as well.
I did not like the fact that that adapter for the nut does not allow you to accurately measure the torque applied. It's a real guess. My cousin the consultant says " Tighten until it strips, then back it off a quarter turn"
Industry standard for Power Plant Maintenance. With my luck it usually just breaks right at the point you think it is almost tight enough.
