Rear mud flap replacement advice please
Old Dec 12, 2021 | 01:31 PM
MAduckhunter's Avatar
Default Rear mud flap replacement advice please
Hi all,
Both rear mud flap brackets on my 2003 disco2 are heavily corroded, to the point the rear finisher and flap fell off on the right and it’s nearly the same on the left. I purchased new rear finishers oem and 2 brackets from rovers north. I went to attempt the job today, I replaced one finisher because it’s held on by screws, but all the other rusty connections are rivets. I tried drilling a few out with no luck, they are so rusted they start spinning.
Any advice on attaching the new brackets so I can hopefully put the mud flaps back on? I wonder if I need to cut it all out and try and figure out a way to attach them. I’ve attached some pics so you can see the extent of it.
Also, the truck is in great shape other than the rear rust!
The finisher/mud flap that fell off.
The old bracket
The new bracket
The new finisher
Old Dec 12, 2021 | 04:00 PM
The Deputy's Avatar
Do you own a four inch grinder or cut off wheel? When dealing with rusted objects, they are a must.
Old Dec 13, 2021 | 08:09 AM
I have recently purchased one.. I haven't used the grinder yet just the cutoff wheel function. I guess it’s time to use it. Do I just grind the rivets until they pop off? Or is there more to it then that? Should I get a rivet tool and use new rivets to install the new shield or self tapping screws and/or bolts and nylon nuts?
Old Dec 13, 2021 | 06:54 PM
Extinct's Avatar
Have you tried drilling the rivets out yet?
Old Dec 13, 2021 | 08:16 PM
yes with no luck. I get through and the whole rivet starts spinning because the surrounding metal is so rusted.
Old Dec 14, 2021 | 01:49 AM
The Deputy's Avatar
Yes, just grind the head off and drill or punch out remaining portion. Yep, pop-rivet gun is a nice tool to add to your toolbox.
XXL
Aug 30, 2024 09:03 AM
Aj6543
Jun 26, 2021 01:07 AM
N E WHR
May 3, 2021 06:20 PM
eskiltell
Jan 31, 2019 05:54 PM
bosshogt
Jan 15, 2012 04:48 PM
