Rear panhard conversion plan
Old Nov 6, 2018 | 08:00 PM
Jeff Blake's Avatar
Default Rear panhard conversion plan
This project has been on the bench for too long. I've read all the threads from the past, and here's what I've got for a plan
Following primarily Dusty1's build (same as ZGPhoto's, but with the axle mount outside the spring perch)
Parts
Panhard Kit: https://www.ruffstuffspecialties.com...og/PANKIT.html
- Axle offset, Frame outside
The kit above seems to have changed a little bit from the photos Zach posted years ago.. they have 3 as opposed to 2 mounting holes now
Install:
  • Bar should be as long and horizontal as possible
  • Frame mount (passenger side)
    • plate frame, Rosette/plug weld bracket to frame & spring perch
  • Axle mount (driver side)
    • Outside spring perch, offset
    • Careful not to heat up axle too much (could ruin o-rings for the half shafts)
    • How to reinforce this bracket?
  • Tack mounts, center axle to frame (straps, jack stands), then measure/cut dom tube
Any other tips to mention to the welder? Like how to make sure the angle of the brackets are good, how to measure/cut the DOM tube to the right length? General procedure tips? My welder doesn't specialize in offroad fab, so I need to spell it out to him.
Photos are from Dusty1's install
Old Nov 6, 2018 | 08:16 PM
ZGPhoto's Avatar
So long as you plate the frame, you'll be good to go with that plan. Definitely make sure the brackets are mounted correctly and the bar doesn't interfere with the axle.
Old Nov 7, 2018 | 11:06 AM
Jeff Blake's Avatar
Thanks Zach... any comment on how that kit has changed a little since you bought it 5 years ago? Difference looks minimal but thought I'd ask
As for making sure my suspension is ready for this, I'm currently running
Britpart 90mm extended bump stops (https://www.britpart.com/parts/suspe...very-2/dc7013/)
OME 763 HD springs, D1 spring seat, Terrafirma retainers, 2" spacer, sway bar deleted
Terrafirma +3" adjustable shocks
My lift is around ~2.3" in the rear. Really struggling to maintain 3".. I need taller and heavier rated springs, but they don't exist
I have 2" extended brake lines, and abs lines. I might need 4" brake lines as they're looking a little tight... other than that, see any issues or room for improvement?
Old Nov 7, 2018 | 01:51 PM
nathanb's Avatar
What does this help with? The radius arms will still bind and limit flex. I thought the Watts link was better provided you have room for it. Are you changing to a panhard rod just because it needs to be longer? Why not make the watts longer?
Old Nov 7, 2018 | 04:39 PM
Jeff Blake's Avatar
There's a lot of info out there on the virtues of the panhard over the watts. I don't want to deal with expensive watts bushings and the panhard will allow greater articulation, have 2 as opposed to 6 joints, and cheaper
Will the exhaust be a problem? Here's a bad pic. Sure seems like its directly in the way. No one has mentioned relocating the exhaust
TaylorCadence
Oct 10, 2022 07:49 AM
Alex_M
Jan 15, 2018 08:47 AM
Dlariv
Jan 26, 2017 11:37 PM
vette427sbc
Dec 25, 2014 01:58 PM
Sfef84
Mar 26, 2008 11:06 AM
