Rear Passenger window goes down but not up.
My rear passenger window decided it will go down but not up anymore. I've looked through some posts here on the forums and suspect a crack/bad solder in the window ECU.
However, the images on those threads don't look like the boxes I have behind my glove box.
Can someone tell me which of these boxes is the window ECU?
Also here's what I've tried:
- replaced motor - Didn't work.
- swapped switches from other door and front control panel - Didn't work.
- pulled out the regulator and checked the roller - it looked fine.
RossN99
01-27-2018 11:18 AM
marlymarl
04-21-2012 12:49 PM
