Rear ride height after new springs
Old Jan 10, 2021 | 11:07 PM
Brandon318's Avatar
Default Rear ride height after new springs
I replaced springs on all four corners of the 2002 yesterday with just new stock-height springs from Lucky8 (Allmakes brand). The fronts are great and sit where they should (500mm) but the rears appear lower to me by a bit and measured 460mm (should be 475mm). We loaded the disco for a trip this morning and it sagged a ton. It's the same kit we always bring on this particular trip, and the new springs sagged way lower than old springs (with 180K miles on them btw). Did I buy the wrong springs? They seem way softer than the stock springs but they should be the same.
Old Jan 11, 2021 | 07:16 AM
zski128's Avatar
Are you sure that the old springs where stock?
Old Jan 11, 2021 | 11:30 AM
Brandon318's Avatar
Yes, yeah.
Old Jan 11, 2021 | 01:39 PM
Best4x4's Avatar
Get a set of D1 spring lower spring perches. You'll gain 1/2 an inch of lift vs the D2 units.
Old Jan 11, 2021 | 01:45 PM
Brandon318's Avatar
Oh, really? They’re just a direct swap? Never heard of this mod before. Cool!
Old Jan 11, 2021 | 02:29 PM
mollusc's Avatar
Yep, I have them installed. Still won't help with the sag rate of the new springs though.
Old Jan 11, 2021 | 03:26 PM
Best4x4's Avatar
Yep it won't help at all with whatever spring rate the springs are rated at when loaded, but unloaded the D1 lower rear spring perches will make it sit darn near level from the sound of your setup. D1 lower spring perches are 100% compatible.
Richard Gallant
Jan 8, 2021 05:22 PM
Alex_M
Apr 1, 2015 10:11 AM
overover02
Apr 24, 2014 12:45 PM
thehun
Dec 5, 2010 08:18 PM
sailorcolin
Jan 20, 2008 09:31 PM
