Rear sunroof - motor test good, opens manually - ECU clicks but won't open?
Old Oct 31, 2015 | 02:36 PM
Extinct's Avatar
Default Rear sunroof - motor test good, opens manually - ECU clicks but won't open?
I have read most all of the sunroof threads - my problem does not seem to be the normal rusty motor/stuck sunroof/blown fuses. I did not see a lot of threads where the ecu was bad for one sunroof but not the other. My rear sunroof will not open, opens fine with the allen wrench, took the motor out and it test fine both directions. I can hear the ECU relays clicking when I press the open/close buttons, but nothing happens, either direction. Does that mean bad ecu? Looked at the wiring diagram on Rave - it seems to be a pretty simple system - fuses/ecu/motors - just wondering if there is anything I am missing?
Hurricane Moon
May 1, 2012 06:55 PM
jhammerstrom
Jun 2, 2010 07:36 PM
discosmurphy
Oct 22, 2008 12:05 AM
