Rear sunroof off alignment question
Old Oct 24, 2021 | 10:38 AM
me 2's Avatar
Default Rear sunroof off alignment question
A couple weeks ago I went to open both sunroofs and the rear one started to make a loud clicking sound. It continued to open and shut but with a lot of noise. Yesterday it stopped shutting all of the way. I looked into it and found that one track on the pass side is not in alignment with the drivers side. Does anyone know if there is a way to realign them? I tried a Allen wrench with no luck. Thanks again.
Pass side
Drivers side
Old Oct 24, 2021 | 03:39 PM
nashvegas's Avatar
I bet it has something to do with broken or missing small nylon or plastic bushings that go on the pegs & slide in the tracks /rails.
What happens is that the pegs, made of pot metal, in the tracks start to bend inwards a bit (you can't bend them back, they break) because the sunroof motor is stronger than the metal pegs -- lack of lubrication over the years, and then the bushings break or fall off. That looks to me like what may have happened,. Very common, starts with clicking. Fix is new sunroof mechanicals / tracks. (sorry)
https://landroverforums.com/forum/di...ushings-20625/
Old Oct 24, 2021 | 03:45 PM
Extinct's Avatar
Remove the glass, remove the gearmotor and the mounts can be shoved all the way forward.
Trigger the motor with it plugged in but not mounted to reset the close position cam switch on the motor. Reinstall the motor and you should be good to go.
BTW, headliner needs to come out for this, do the sunroof reseal at the same time
Old Oct 24, 2021 | 04:31 PM
me 2's Avatar
Thanks guys, let me get in there and see if any parts are damaged or missing, if not I’ll try the repair!
Old Oct 26, 2021 | 04:01 AM
frostythor's Avatar
when I did mine it was the drive gear worn, the window are operates by a wire worm, mine was totally dry, and a missing plastic guide, I made a guide out of a piece of plastic, removed the wire drives and oiled them , replacing them, the fitted a new gear drive, all fine now for 18 months
Old Oct 26, 2021 | 06:56 PM
me 2's Avatar
Well I pulled the headliner and removed the sunroof. Looks like the brackets are bent! Is this correct?
Old Oct 27, 2021 | 04:54 AM
frostythor's Avatar
YE$, you will need to replace them it you cant straighten them or they break
Old Oct 27, 2021 | 04:59 PM
Extinct's Avatar
If you remove them from the tracks and put lot of heat on them then you might be able to bend them back without breaking them, I recommend a map gas torch. hot enough to get them solved but not hot enough to melt the aluminum
Old Oct 28, 2021 | 06:39 AM
me 2's Avatar
Well that didn’t go well lol. Guess I have just a skylight for a while. Thanks for y’all’s help!
Old Jul 10, 2022 | 10:42 AM
nashvegas's Avatar
@austinlandroverbill in post 6 here, you can see what I mean when I say "bent" posts . Hope it's helpful for ya
cvhyatt
Dec 29, 2019 12:10 PM
Spyder7892
Jul 5, 2018 08:47 AM
Luckyjayb
May 30, 2017 10:04 AM
Disco2001
Nov 10, 2013 04:42 PM
twalter87
May 23, 2011 08:40 PM
