Weird Sunroof Issue
Old Jul 5, 2018 | 06:57 AM
Spyder7892's Avatar
Default Weird Sunroof Issue
Hey Guys,
I was wanting to see if anyone has come across this issue in the past and if so what did you do to fix it?
I got in and hit my open front sunroof button (vent position) like every morning and it didn't do anything, when I hit the open the rear sunroof button (vent position) they both opened together to the vent position. Then I hit the front sunroof button to fully open the sunroof (nothing happened) and then when I hit the button to fully open the rear, they both opened together again. The same thing happened when I went to close them, the front did nothing but the rear seemed to control both. Then I tried opening the rear first, when I did this just the rear opened and then when I hit the front button, it would not do anything until I hit the rear button.
Fast forward a week, both sunroofs had been opening and closing even though the switches are acting like I mentioned before. This morning I when I got to work I cannot get the front sunroof to close. The rear functions normally and I can hear the front one trying to move (you can hear the motor attempting to move but nothing happens). I manually close the sunroof via the access panel and it closes without resistance so I know it has not jumped the track. Then just to see, I hit the open button and it opens like nothing has happened but then would not close back.
Does anyone have any idea what is going on here? I do not know if I should be looking at the switches, the ecu for the sunroofs or the front motor itself?
Any help would be appreciated!
Old Jul 5, 2018 | 08:35 AM
ahab's Avatar
You can try swapping the switches to see if the behavior changes.
Old Jul 5, 2018 | 08:47 AM
abran's Avatar
Sounds like the sunroof ECU
BritCars
Mar 8, 2021 09:53 PM
Luckyjayb
May 30, 2017 10:04 AM
jringeno
Jun 2, 2016 08:50 AM
OCMike
Nov 11, 2014 08:59 AM
iownme
May 7, 2011 07:10 AM
