Rear Wheel Hub Leak
Old Mar 27, 2009 | 05:24 PM
Disco Alan's Avatar
Default Rear Wheel Hub Leak
My driver's side rear wheel hub (03' 55k) has been leaking for a while. At first I could see the caliper looking "wet". After I topped off the rear diff with Mobil 1 synthetic 75w90 that leak seemed to have slowed down quite a bit. I'll check the breather tube tomorrow. If that is not the problem I have a few questions:
1] Is it ok to use heavier oil in the rear diff (e.g. 75w140) and regular weight (75w90) in the front diff and t-case?
2] I've read a couple posts here and still am not sure whether the D2 hub seal is replaceable or not. Can I just have the hub seal replaced or do I need a new hub?
Thanks.
Alan
Old Mar 27, 2009 | 05:54 PM
The heavier oil may slow the leak down a little but at some point the brake pads will get wet.
Time to start looking for another hub, consider a guaranteed used on from Roverlandparts.com
Old Mar 27, 2009 | 07:50 PM
Most likely it is not the hub leaking but the axle seal.
Remove the hub and there is a seal where the hub mates to the axle, that seal goes bad, its like a $3 part but you must remove the hub to replace it.
Racer X
Oct 10, 2016 09:32 AM
marizcal
Apr 10, 2014 09:11 AM
badicedog
May 21, 2011 11:03 PM
lsmit605
Nov 14, 2010 05:35 PM
98xc800
Sep 30, 2008 04:51 PM
