Rear wheel sensor, no grease.
Old Apr 28, 2014 | 09:30 PM
ls1morethanyou's Avatar
Default Rear wheel sensor, no grease.
So I replaced the rear left speed/abs sensor and the three amigos came back almost immediately.
The hub seemed to not have grease inside of it or at least none that I could see. From the threads I have read the grease helps the sensor get an accurate reading.
Do I remove the hub and regrease, remove both hubs and remove the inner seal and run gear oil?
The only sensor that is acting up is the rear left, I'll remove the rear right tomorrow to check the status tomorrow.
Old Apr 28, 2014 | 10:24 PM
jfall's Avatar
Grease on the sensor?
wifes' tale.
Wheel bearings need to be greased.
And the wheel bearing needs to be properly tight.
The sensor need to be near the toothed pattern to pick up a signal.
Too far - and it flakes out.
Old Apr 28, 2014 | 10:50 PM
wifes' tale.
i will be greasing up the hub tomorrow as per this guy trying it out. the bub doesn't squeal or have play in it. hopefully thats the ticket.
Originally Posted by Roustabout
I had a spare hub kicking around so I gave this a try. I pulled the end off my grease gun and just pressed the fitting against the o-ring in the sensor hole. Pumped it full of grease while rotating the hub. It took the grease fine and pushed a little bit of the old grease out around the circumference of the seal. I did this to both my rear hubs as one had been leaking a tiny bit of diff oil and had started to make a little noise when turning. There was no play that I could detect in the hub and now with the addition of the grease I have no more noise.
Seems like a viable method to prolong hub life especially if diff oil had been making it's way past the seal and diluting the grease.
Old Apr 29, 2014 | 09:48 AM
The hub is not designed to be greased, it is a sealed unit.
Do you have a scanner that read ABS codes, how did you verify it is the r/r area with a problem?
Old Apr 29, 2014 | 01:26 PM
i have a cdp+ running the 2013.3.3
R/L is the issue. i was going to try and put grease in via the sensor area.
Old Apr 29, 2014 | 01:41 PM
dusty1's Avatar
I have put grease in one, that way. used a long needle and pushed it in the teeth. I also have one hub that came with gear oil in it, not grease....dunno what the deal is with that. have you tried to swap that sensor with another? I have a sensor you can splice in, if you need it.
lemme know. I am headed north tomorrow and thursday. mckinney
Old Apr 29, 2014 | 01:55 PM
i swapped in the replacement sensor i bought and this is how all of this has come about, though i did buy a cheap one with the plug at the frame and not the splice in one to the abs box. i guess i should try and check continuity to the slabs box before i try another cable. for sure add the grease though in the interim.
Old Apr 29, 2014 | 09:04 PM
i am sure the hub is bad now. the new sensor is either a smidgen too short or its too accurate as the lights come on faster than the original sensor.
after packing it with grease the old sensor on a straight road does fine, then when there is a bump the three amigos show up.
i guess new hub for me, weird thing is there is no movement of the hub by the wheel or any sounds. i guess i just caught it in time.
schwaggy
Dec 25, 2014 12:19 PM
TOM R
Jul 17, 2014 10:30 PM
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
twaszak
Jun 4, 2011 07:49 AM
