wheel bearing grease
Old Jul 14, 2014 | 10:22 PM
TOM R's Avatar
Default wheel bearing grease
Getting ready to replace the rear hub bearings and seals next few days I hope
I have several tubs of grease all different color
I got red grease napa
Blue Dryden grease think this is a waxy grease for like boat trailer bearings?
A light blue grease looks like lithium ??? Think its lubriguard?
And brown grease
All say disc brake bearing grease all have same ansi rating which one is best for this?
Old Jul 14, 2014 | 10:42 PM
CUpgt's Avatar
I just used valvoline disc brake grease. Comes in a can and is red. No issues. I do run the rears wet though so not any grease left
Old Jul 15, 2014 | 05:39 AM
MM3846's Avatar
i usually use lucas x-tra heavy duty (the green stuff), but the best stuff i've seen is made by amsoil... too rich for my blood though.
Old Jul 15, 2014 | 01:55 PM
TOM R's Avatar
Well spelled pass front and looks loaded with muddy rust grease so guess I am doin them too, just shoot in the red for now thanks guys, I was only thinking the Dryden blue for this exact reason
Old Jul 15, 2014 | 06:35 PM
CUpgt's Avatar
I wouldn't shoot it with a gun. Get a can and pack the bearings and everything you can around them
Old Jul 15, 2014 | 08:29 PM
TOM R's Avatar
Sorry auto correct sucks
When I pulled front hubs to do the terra firma hubs, driver front looked good packed, clean
Pass side muddy watery grease rust mess, did new timkens, double lip seal. Packed with some red Valvoline European spec grease I had
I expect same mess in rear bearings
I cleaned and packed like normal, you saying I should have slopped a bunch in the hub between the bearings?
Old Jul 16, 2014 | 10:01 PM
TOM R's Avatar
Pass rear was worse, removed caliper and rotor dropped, pulled the bearings and same muddy water crap rollers were falling out of outer bearing, guess 165 k miles they were due for replacement
Old Jul 17, 2014 | 10:30 PM
CUpgt's Avatar
My bearing s were cruddy looking but they cleaned up pretty good. I would throw them back in in a pinch and run them, and that says a lot considering roller bearings are my life for 45-50 hrs a week
ls1morethanyou
Apr 29, 2014 09:04 PM
MarkSF
Mar 4, 2014 11:31 AM
Grlica
May 1, 2013 06:13 PM
cobbcj7
Mar 10, 2013 09:24 AM
Love U Landie
Feb 4, 2013 03:17 PM
