rear window rubber weatherstripping removal
Old Sep 27, 2011 | 11:04 AM
GreedyRover's Avatar
Default rear window rubber weatherstripping removal
Got a rusty metal divider strip on the rear door windows. Tips/tricks on removing the big **** rubber weather stripping. TIA
Attached Thumbnails rear window rubber weatherstripping removal-img00373.jpg
Old Sep 27, 2011 | 01:31 PM
DiscoWest's Avatar
Follow rave procedure to remove the inner door panel, then you can remove the weatherstripping. It is only held on by two metal clips, but the door panel and inner weatherstripping has to be removed first. Once you get it removed, you may have to pull the whole window frame, as the rust is likely not isolated to that one spot. When I changed my power locks I found the lower part of all the window frames were rusted and needed a respray.
Old Sep 27, 2011 | 01:37 PM
DiscoWest's Avatar
Old Sep 27, 2011 | 07:38 PM
0304Disco's Avatar
I have the same problem with my 03'. Going to try and repair the rust but may need to buy a replacement set for $300.00 from roverland.
Old Sep 28, 2011 | 07:28 AM
i'm just going to remove all the rust and spray paint.
s10lowrider1994
Sep 13, 2011 02:51 PM
thehun
Nov 27, 2010 10:02 AM
LeakyDisco
Nov 9, 2010 08:59 AM
DiscoRom
Nov 2, 2009 11:52 PM
DuplinDisco
Feb 4, 2008 06:30 PM
