Rear window washer works but NOT the wiper?
Old Mar 10, 2009 | 03:32 PM
VikingDiesel's Avatar
Default Rear window washer works but NOT the wiper?
Any ideas? Common issue? I checked the fuse and the fuse is OK, is the motor most likely bad?
Old Mar 10, 2009 | 03:59 PM
Bad motor.
www.roverlandparts.com
www.autosportsunlimited.com
Did you try and use it while it was frozen to the glass this winter?
Old Mar 10, 2009 | 04:02 PM
no i didnt, when I press the button, its completely dead. NO NOISE, could it be something with that actual button or most likely motor?
Old Mar 10, 2009 | 04:03 PM
Could be the button, switch it with another button, like for the rear washer since you know that one works.
Just pop them out, switch the plugs and see if it works, if so you need a new switch, if not then you need a new motor.
Old Mar 10, 2009 | 04:12 PM
ok, thanks for the info. BTW, im still confused on the rear window issue, i talked to a land rover tech here and he said there are a bunch of different ECU's behind the glove box and that its hard to tell which joint needs to be soldered.
Old Mar 10, 2009 | 06:33 PM
I used to have a "how to" link bookmarked, but I lost it. Easy to do when you have 300 bookmarks.
It should be labeled "window lift" or some such.
Also try Googling it.
how to fix...or some thing to that effect.
Old Mar 10, 2009 | 11:05 PM
got it: http://www.discoweb.org/window/index.htm
My last qustion is how do I know whats bad and what needs to be soldered? According to the pic, it looks bad but then so do some other soldering points
Old Mar 11, 2009 | 07:20 PM
It will be cracked at the base of the solder joint.
You can just go ahead and resolder all of them.
Newscotlander
Jul 21, 2025 02:02 PM
hilltoppersx
Sep 22, 2010 07:44 PM
4score
Feb 16, 2010 12:32 AM
krazzz
Jan 15, 2010 07:17 AM
wildhorses
Oct 18, 2005 05:29 AM
