Rear windows dont work but motor and regulator is fine??
It is behind the glove box, so you need to open the glove box and then take it out.
Open the window ecu and look for broken solder joints.
Clean with rubbing alcohol and a Q-tip, apply flux and use a low temp pencil solder to redo all the joints.
If you have never soldered a circuit board before you must use a low temp soldering pencil and do NOT touch the circuit board with the pencil.
and that is instead of buying the $15 repair kit? So I take out the glove box and open the ECU and resolder what joints? This is just to fix my rear windows, I need some pics to get an idea, if possible
all of your windows are wired to individual harnesses... are you positive that just the window switch is not bad? take out the switch for the window that for sure works and plug it into the harness for one of the rear windows... eliminate the obvious before you go tearing into more complicated fixes...
This is assuming that you have ruled out everything else.
Once you get the repair kit it will have instructions.
well, the main switch in the middle console as well as the switch in the actual door doesnt work, so that means thats not the problem, since the other rear window doesnt work as well
johnnyjohnny
Feb 23, 2014 08:55 AM
wallem
Jun 13, 2012 07:58 AM
booper169
Nov 9, 2010 09:10 AM
bcolins
Oct 20, 2008 10:52 PM
