Rear Windows Inoperable
Old Apr 13, 2008 | 02:21 PM
wick_60010's Avatar
Default Rear Windows Inoperable
I have a '99 Disco Series I, and both rear windows quit working at the same time (fortunately they're stuck in the up position). Can't get them to move at all. Fuse (in the dash) is OK. Front windows work fine. Tore the console apart, but am not really sure what I'm even looking at, as I'll admit I'm not the most mechanically inclined guy in this forum! Any advice? Thanks a lot!
Old Apr 13, 2008 | 02:42 PM
Urban Panzer's Avatar
Default RE: Rear Windows Inoperable
what about the switch in the console that turns of the rear windows ? to stop kids messing with them
Old Apr 13, 2008 | 02:56 PM
If it's not the window lock then switch a known good switch with a "bad" one and see what happens.
If it works then the switch is bad.
Old Apr 13, 2008 | 04:28 PM
wick_60010's Avatar
I tried turning the safety button on and off, and it made no difference. I also disconnected one of the connections behind a front window switch and hooked it up to a rear window switch. It still operated the front window (which worked fine). I hooked up one of the rear connections to a front window switch and nothing happened.
Old Apr 13, 2008 | 04:39 PM
a2tripp's Avatar
does the rear switches work?
Old Apr 13, 2008 | 04:42 PM
Do the switchs on the rear doors work? Or is it only the ones in the console?
Old Apr 13, 2008 | 05:09 PM
wick_60010's Avatar
No, the rear switches (in the backseat) do not work. Not sure if this is an important detail, but both of the rear windowsGRADUALLY became inoperable. For a while there, they would both work one day, not the next, type of thing. Then they both just quit working.
Old Apr 13, 2008 | 05:12 PM
Yes that is valuable detail.
You need new window motors/regulators.
Old Apr 13, 2008 | 05:20 PM
a2tripp's Avatar
does anyone know if the circuit for both windows shares a common ground? or are both of the rear windows both controlled by the same output ona control module or something? i would like to know since i have a similar issue.
Old Apr 13, 2008 | 05:21 PM
wick_60010's Avatar
I just looked up window motors, and this says that the "left" motor controls the front AND rear left windows, and the "right" motor controls the front AND rear right motors....
http://www.autopartswarehouse.com/se...294967267+9329
