Rear Windows Inoperable
Old Apr 13, 2008 | 05:43 PM
wick_60010's Avatar
Default RE: Rear Windows Inoperable
But then again, on ebay: http://cgi.ebay.com/ebaymotors/Land-...RCHQ3aUSQ3a101
Is this the part I need? Is it relatively easy to install?
Old Apr 13, 2008 | 06:12 PM
ajz399's Avatar
7th Gear
Idid this to my 1997 discovery and it worked like a charm. http://www.discoweb.org/window/index.htm
Old Apr 13, 2008 | 06:14 PM
I have no idea.
Talk to a glass shop and see how much they want to do the work if you buy the part.
Old Apr 13, 2008 | 06:20 PM
ORIGINAL: wick_60010
I just looked up window motors, and this says that the "left" motor controls the front AND rear left windows, and the "right" motor controls the front AND rear right motors....
http://www.autopartswarehouse.com/se...294967267+9329
I think what they mean is that the same motor fits both front and rear doors. You have to have a seperate motor for each door.
Old Apr 13, 2008 | 06:33 PM
wick_60010's Avatar
I'm a little suspicious about it being the window motors, the more I think about it. I mean, what are the odds that they would BOTH go out at the EXACT same time?
Old Apr 13, 2008 | 06:37 PM
You have a good point, it could be the window ECU.
Old Apr 13, 2008 | 06:59 PM
okdiscoguy's Avatar
Just read this post,
DO NOT ORDER NEW MOTORS!
Pull the window lift ECU and re-solder all of the connections.
http://www.discoweb.org/window/index.htm It was given to you earlier, and I would put $5 that this will fix it...
Old Apr 13, 2008 | 09:58 PM
wick_60010's Avatar
Thanks, ajz. I followed the link immediately. What nice photos - I plan on giving this a shot first thing tomorrow.
Old Apr 14, 2008 | 01:52 PM
Landzu's Avatar
Did that fix it ?
Old Apr 14, 2008 | 04:36 PM
wick_60010's Avatar
YES! I'll be damn3d, but taking the circuit board out and soldering it did the trick! Itlooked EXACTLY like the one on the http://www.discoweb.org/window/index.htmlink. I can't believe it. Took me about 4 hours (as I previously admitted, I'm not the most mechanically inclined guy these days), but it did the trick. Thanks a TON, guys - I really appreciate it.
OK, next question (unrelated to the rear windows issue)...why does my driver's side seat heater not work? ; )
