Rear Windows Inoperable
Old Apr 14, 2008 | 10:22 PM
  #21
wooz797's Avatar
Default RE: Rear Windows Inoperable
if you can pop the inside door off and check for voltage at the connector in side the door with a voltmeter.
Old Apr 14, 2008 | 10:27 PM
  #22
okdiscoguy's Avatar
Check the fuse under the seat. If it is good, check the heater element. It plugs in under the seat and you can ohm out the element.
Old Apr 15, 2008 | 08:47 AM
  #23
raid13's Avatar
last discovery that i had this problem a window lift ecu fixed this
Old Apr 18, 2008 | 10:24 PM
  #24
rwarren92's Avatar
mine does the samething and i have to hit the back of the center console and they will work again its a bad connection some where but im to lazy to take it apart
trp34
May 2, 2012 04:56 PM
raj49
Jan 6, 2009 06:27 PM
msl64
Nov 20, 2008 07:56 PM
95discotn
Oct 13, 2004 09:28 PM
95discotn
