Rear Wiper Fluid Leak
Old Jan 10, 2015 | 01:07 PM
jobooth's Avatar
Default Rear Wiper Fluid Leak
I'm trying to track down a leak in the tubing for my rear wiper sprayer. Everything in the rear door is fine. When I hit the sprayer, I can hear the pump whine and the arm moves. I get a little bit of fluid from the sprayer head on the arm, but I also get a whole lotta dripping from the passenger side in front of the rear bumper. I can't track the tubing forward from the wiper arm. It goes into the door, into the car and from there I don't know. I looked through the RAVE manual but can't seem to track it. Maybe I missed it? Wondering if anyone has a 'map' of the tubing so I can figure out where the leak is coming from.
2004 Discovery II in North America
Old Jan 10, 2015 | 11:02 PM
lordmorpheus's Avatar
Have you already remove the inner panel on the rear door? My best guess is either the hose has a hole in it somewhere inside the door, or the check valve inside the door is leaking. If you open the rear door, is the flexible rubber tube on the hinged side wet? That is where the door wiring and washer tube connect into the door.
Old Jan 12, 2015 | 01:27 PM
jobooth's Avatar
Inside of the rear door is clean and dry. I just replaced the valve as I think the previous one was clogged but not I'm seeing wiper fluid dripping from under the car just in front of the rear bumper. I'm trying to trace the tubing as there's got to be a leak in it somewhere. Problem is, it looks like it's routed in the frame and I can't get to it.
bah
bcolins
Feb 2, 2014 09:40 PM
bcolins
Jun 22, 2013 08:55 PM
junior496
Jan 26, 2011 05:28 PM
hilltoppersx
Sep 22, 2010 07:44 PM
millejdq
Dec 6, 2007 12:23 PM
