Drive train noise
Old Jun 18, 2022 | 06:30 PM
merebel's Avatar
Default Drive train noise
Ok been sorting out lots of issues with the drivetrain. I had a clicking left front cv joint, that has been replaced.
front drive shaft 2 years old.
had drive shaft vibration under back seat area so I replaced the u joint and rubber coupler.
so after all of this I still had a bad growling vibration when letting of the gas. But accelerating it went away.
so this morning I pulled the front driveshaft. Took it out and no more noise and vibration. Now this was the first time I had to use a pry bar to pop the drive shaft out.
Drive shaft came from lucky8.
so do I have a bad ring or pinion? Or did I crap another drive shaft?
Old Jun 19, 2022 | 03:17 PM
Sandman614's Avatar
My diff did the opposite. It would make a rumbling/shaking when on the gas and go smooth when I let off the gas.
Old Jun 20, 2022 | 06:35 AM
merebel's Avatar
well I thought I might have still heard a noise with the driveshaft out if it was the front diff?
Old Jun 20, 2022 | 01:06 PM
Sandman614's Avatar
It depends on what the problem is. In my case the pinion bearings were toast and only made noise/shaking under input load.
Dmenchaca
Nov 24, 2017 07:49 AM
Daedrix
Apr 9, 2016 03:21 PM
REVS
Oct 16, 2013 10:38 PM
glassman66
Feb 12, 2012 10:21 AM
northridgeconstruction
May 24, 2011 09:05 AM
