Rebuild injectors vs. Rebuilt injectors??
Old 02-09-2016 | 09:46 PM
Madlands's Avatar
Default Rebuild injectors vs. Rebuilt injectors??
On my 04 I've been chasing P1173 forever. Replaced cats and all 4 o2's. Done multiple smoke test and found nothing. I've finally decided it must be a leaking o-ring on an injector.
So there's multiple questions here. Who sells the best/most affordable rebuilt injectors? Who sells the best rebuild kit? Is one method preferred over the other? What all should I expect to encounter and replace when I decide to swap the injectors out?
Old 02-09-2016 | 11:06 PM
Alex_M's Avatar
You probably don't need to do a complete rebuild unless you just want to. If you go to the link in my signature I believe there is a link to a write up for a cheap diy injector cleaner. Then get yourself a new set of o-rings to put on and some RTV for the plenum gasket then you'll probably be good.
Another idea is that it could be an exhaust leak. If you've got a pre-o2 exhaust leak (usually between the exhaust manifold and pipe, the gaskets kinda blow out the side) then that allows oxygen into the exhaust stream and the sensor registers that as a lean running condition.
Old 02-10-2016 | 12:39 AM
number9's Avatar
Haven't dealt with mine yet so won't be of much help. Have looked around some for rebuild/service kits. Link for one below and several available on eBay from $20 and up. Looks to be a fairly simple process.
Bosch Type 3 Fuel Injector Service Kits 002 - Mr Injector Parts
Old 02-10-2016 | 10:54 AM
drowssap's Avatar
there should be a great right up on how to clean, rebuild and test injectors.
i don't remember who posted it (sorry), but it was very complete comprehensive right up.
ImQuattro
01-26-2015 12:07 AM
FlyingZebra34
07-31-2013 07:00 AM
zukijames
11-16-2012 01:13 AM
SolbergFanBoi
12-23-2011 09:57 AM
Spike555
06-21-2010 08:27 PM
