Rebuildable Tensioner Pulley
Old Oct 20, 2020 | 05:50 PM
Extinct's Avatar
Default Rebuildable Tensioner Pulley
So I typically replace all the idler pulleys on my restoration trucks. The two stationary idlers are of course steel and I just replace the bearings in them because it is much cheaper than the whole pulley and I have access to a press. The factory tensioner pulley however is plastic with the bearings molded in to position. However the Gates pn 36102 is a steel pulley with a replaceable bearing, not than any of us will likely put enough miles on their truck to need another replacement.
Just thought I would share the info.
Old Oct 20, 2020 | 06:26 PM
boston4's Avatar
This explains a lot. I went to replace my tensioner pulley and found that the replacement I ordered was plastic, while the one in the engine was metal. Kind of a head scratcher since I figured that the original would have been metal like the idlers. Thanks!
redwhitekat
Nov 21, 2019 07:18 PM
redrover75
Jul 1, 2015 12:56 PM
disc oh no
Oct 11, 2012 11:00 AM
73S3IP
Aug 10, 2009 08:46 AM
ajh
Dec 19, 2007 11:30 AM
