rebuilding motor...i have some questions
Old Dec 3, 2009 | 11:29 AM
jnice's Avatar
Default rebuilding motor...i have some questions
i got this 98 block from D1 at the machine shop now getting bored, honed, and cleaned. We're not sure if the crank is ok or not yet. assuming it isn't, can I get the 4.6 crank/push rods/pistons and pop in there to stroke it out? if we like this idea, where is a good afforrdable place to buy them?
Also, where's the best place to buy engine rebuilding kits? We're going through everything, and throwing away the EFI, going straight 4 barrel carbs and distributor...what a beautiful thing.
Old Dec 3, 2009 | 11:34 AM
Besides that sort of work will nearly excede the valve of your truck, your tranny and spider gears won't take that sort of power bump.
Why not drop in a 4.6 short block and a cam and be happy?
Old Dec 3, 2009 | 11:50 AM
jnice's Avatar
well im on a budget, and I already have the 4L block, I can be happy with 4L just thought if the crank was bad..since I already have to buy new pistons.
Old Dec 3, 2009 | 12:50 PM
The least expensive way to get that crank and rods would be out of a junk engine and have them cleaned up by a machine shop.
If you want some power, look at a cam, lifts and HD springs, mabey clean out the heads so they breathe better.
Old Dec 3, 2009 | 06:49 PM
Willie00d2's Avatar
If you use a long stroke crank you will need shorter rods.
Willie
Old Dec 3, 2009 | 07:11 PM
Yes you can throw in a 4.6 cam and crank.
Thats all a 4.6 is, is a stroked 4.0.
I do not know if a 4.6 has a longer or shorter throw than a 4.0 or not, but if you use 4.6 rods then that is a non issue.
Unless you can find out for 100% that the 4.0 and 4.6 use the same rods.
Old Dec 4, 2009 | 08:15 AM
jnice's Avatar
The cam I have is aftermarket and more beefy already. I just need to figure out the bottom end. Do I also need the flywheel and what not from a 4.6 crank if I find one? a friend told me if I switch cranks i have to get the all the bolt on parts that match it. (besides connector rods)
Old Dec 4, 2009 | 09:12 AM
jnice's Avatar
I'm going to call around to the local salvage yards for a 4.6 Crank/rods/pistons. What years can I ask for that will work in my 98 disco 1. (i have the gems engine.)
dr. mordo
Oct 6, 2012 06:20 AM
Osiris
Sep 19, 2011 09:17 PM
Bundu
Jul 8, 2010 04:45 PM
turbos4audi
Nov 28, 2009 05:48 AM
sloppyjoe
Nov 18, 2008 06:16 PM
