Rebuilding a rear hub for a 2003 D2
Old Dec 7, 2015 | 04:02 PM
ATLDisco's Avatar
Default Rebuilding a rear hub for a 2003 D2
Ok,
So I've got a rumble from driver's rear hub. After looking at BPUtah's site, then changing my shorts over the price, I found this writeup:
Replacing a Rear Hub - Land Rover Technical Archive - LR4x4 - The Land Rover Forum
Can anyone comment as to viability of this? Is it a d1 only deal, and we are cursed with these sealed, non rebuildable units?
$400/wheel is just madness for a truck worth maybe $6K.
- dc
Old Dec 7, 2015 | 04:14 PM
Gripen's Avatar
Yes, we are cursed with sealed hubs.
Old Dec 7, 2015 | 04:25 PM
Alex_M's Avatar
Check eBay, you can find them for less than $80 each new. Good quality, I've had one on my truck for several thousand miles.
Old Dec 7, 2015 | 07:16 PM
ATLDisco's Avatar
Ah yes, the FleaBay.
I'll hunt around there. For less than 25% of the cost, it seems like a no-brainer.
thank you
- dc
Old Dec 7, 2015 | 07:20 PM
ATLDisco's Avatar
TAY100050 | Hub And Sensor - Wheel - Land Rover Part TAY100050
Old Dec 7, 2015 | 07:48 PM
Alex_M's Avatar
Finally back and on my computer. Here's the one I have.
Old Dec 7, 2015 | 08:19 PM
ATLDisco's Avatar
says its for the front. are they interchangeable?
Old Dec 7, 2015 | 08:31 PM
Alex_M's Avatar
Ah, I forget about that every time. I cant remember which, but either the front or the rear has a longer wheel speed sensor plug, that's the only difference between the two. I believe the front is the longer one, so it should work in the rear, but someone please confirm or deny that for me.
Old Dec 8, 2015 | 09:23 AM
drowssap's Avatar
both front and rear call for a tayor 100050 replacement hub, so the sensor could be the difference.
BPU has one mark rear with the o-ring for 140
Old Dec 8, 2015 | 11:42 AM
WNYErikDiscoII's Avatar
Former Sponsor
Front and rear hubs are the same, only difference is the ABS sensor
