Recent work done and more needed
Old May 2, 2013 | 05:31 PM
VC gaskets need to be snugged each oil change, just the nature of the beast. Takes a skinny or 1/4 inch drive socket, 8mm 12 point
Old May 2, 2013 | 05:55 PM
tantra12's Avatar
Heading off to get one now.
Old May 2, 2013 | 07:11 PM
tantra12's Avatar
Well, after 3 parts stores not a single one had the 8mm 12 point socket.
Old May 2, 2013 | 07:29 PM
Got mine at Lowes, it is a 3/8 drive, but the body is "necked down". Sears also has them.
Old May 8, 2013 | 03:05 PM
tantra12's Avatar
I found the right socket and was able to tighten one of the bolts about a half turn- certainly a lot more than I was expecting! I will clean the area and see if there is any other leaking. On a side note I was only able to tighten the two "outside" on each cover due to not having access to the other ones. Was I missing something or should I have been above to get to the other ones without having to remove other stuff?
Thanks for the help!
glassman66
Jul 17, 2012 08:31 AM
GamecockRover
Jul 16, 2012 02:00 PM
bcolins
Nov 5, 2011 05:09 PM
bcolins
Oct 27, 2011 11:13 AM
kfx4001442
May 18, 2008 09:50 PM
