Recognize these bolts?
Old Dec 9, 2017 | 10:44 PM
Jwehking's Avatar
Default Recognize these bolts?
Reinstalling my engine on 03 Discovery and have these two left over. Head is 10mm and 11mm and 1” of thread. Can’t figure out where they go. Head is grimy so thinking external
Attached Thumbnails Recognize these bolts?-ccf6a656-50e4-4047-985e-d36fb31816ff.jpeg
Old Dec 10, 2017 | 12:59 AM
The Deputy's Avatar
Knock sensors or motor mounts? I can remember grabbing an 11mm socket...but don't remember exact for what. I'll be out in the varage today, I'll report back if I can come across these bolts.
Brian.
Old Dec 10, 2017 | 05:07 AM
abran's Avatar
Negative ground cable on driver side head and metal heater core pipe to passenger head.
or missing head bolts...
Old Dec 10, 2017 | 05:51 AM
The Deputy's Avatar
Yeah, kind of thought about the ground cable after I posted. I know there were two unusual size wrenches I used during the removal/install of my engine last year. A 11mm and a 14mm. Now, that I think about it...l believe it was the motor mounts bracket had the 14mm headed bolt. Remember one of the odd sizes being below, because I had to get up off the creeper...and I hate that at 57 anymore...lol.
Usually, you can grab a 8mm, 10mm, 13mm, 15mm, 17mm, 18mm and 19mm...socket and wrench...and disassemble about any foreign car. It's odd when you run into 11mm, 12mm, 14mm or 16mm.
Anyhow, if you only have two bolts left...you must be pretty close to go time. Congrats, on the engine swap.
Brian.
Old Dec 10, 2017 | 08:20 AM
Jwehking's Avatar
Thanks and great thoughts. On both the motor mount top hole and the
Heater pipe outlet I struggled to figure out what bolt to use. I used some short grounding type flanged bolts about 3/4” long on those spots thinking these were too long. For at least one of those I dipped into my tool box
Old Dec 11, 2017 | 10:46 PM
jfall's Avatar
grounding strap from cylinder head to fire wall.
Old Dec 13, 2017 | 01:39 PM
grammin's Avatar
Maybe tranny cooling lines clamp to engine. Not sure
dr.lazzaroni
Tires
Nov 8, 2017 02:57 PM
Drillbit
Off Topic
Apr 6, 2017 08:01 PM
Squid4life
Dec 23, 2016 06:03 PM
WaltNYC
Apr 12, 2012 11:00 AM
94svt50
Jan 1, 2012 03:03 PM
