Recommended brakes?
Old Jan 12, 2010 | 04:05 PM
lipadj46's Avatar
Yeah you better knock on wood I had a bad hub fixed it, got rid of the Amigos. Now my rear hub went bad and I have to replace it. Glad I have a good scanner.
Old Jan 12, 2010 | 05:23 PM
yloDiscoII's Avatar
I just knocked again...tried Oak this time for good measure
Thanks for the advice, I'll double check everything again to make sure i don't have any lurking problems. Still happy the Amigos are gone...for now
Old Jan 12, 2010 | 09:15 PM
Zonk872's Avatar
Default Code Scanned at Autozone
I stopped by Autozone to read the codes. It came up P1590 Their computer said it can be one of a few things:
- neutral position switch circuit high input probable cause
- open or short circuit condition
- poor electrical connection failed neutral position switch
Way over my head... any thoughts? How bad is it to drive my Discovery w/the four codes lit up on my dash? I drive to work 1 mile and back 1 mile and then use the company truck. I am due for a tire rotation and will have they look at the pads/rotors this weekend.
Thanks for all of the input on this forum. I appreciate it!
Zonk
Old Jan 12, 2010 | 10:03 PM
lipadj46's Avatar
1590 is just the ODBII code for the 3 amigos, it actually lights up your ABS light. You need to get your ABS codes read and autozone cannot help you there. Either buy an ABS AMigo or go to the dealer,
Old Jan 13, 2010 | 08:09 AM
flroverguy's Avatar
Check out www.e2orlando.com
best land rover shop around. and way cheaper then dealer
ghinesley
Dec 19, 2021 03:50 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
DuplinDisco
Jan 24, 2008 10:44 AM
DDLR3
Jan 6, 2008 08:35 PM
rover2003
Dec 8, 2007 08:40 AM
