recommended pads and rotors, all four corners
Old Mar 24, 2026 | 11:24 AM
jastutte's Avatar
Default recommended pads and rotors, all four corners
my '04 Discovery needs new pads and rotors. i was reminded again of this after a near miss this weekend that required heavy braking and swerving off the road in order to avoid T-boning a pickup and his trailer.
fortunately, i was already slowing down since the speed limit had dropped from 55 to 35 inside the town limits.
i do some light towing on occasion and haul construction materials usually 1,000 lbs and under.
any recommendations on heavy duty pads and rotors? i'm willing to spend the money for stopping power and safety.
Old Mar 25, 2026 | 07:42 PM
jastutte's Avatar
i figured i try the Brembo pads and rotors. i'll post up if they're disastrous.
Old Mar 25, 2026 | 09:11 PM
mln01's Avatar
In 22 years owning my '99 DII I have replaced pads and rotors at all four corners of the truck more than a few times. I have always used the least expensive I could find from national parts chains, L8, and even from Amazon.
No problems whatsoever, but I very rarely brake hard, if ever.
YMMV
Old Mar 26, 2026 | 07:03 AM
WaltNYC's Avatar
On my D1 I have had good luck with Brembo rotors and either Wagner or Akebono pads
Old Mar 26, 2026 | 08:17 AM
jastutte's Avatar
YMMV
i've done the same in the past. but, after the incident last weekend and considering i pull a trailer around town i'm willing to spend a little more for peace of mind.
Old Mar 26, 2026 | 08:18 AM
jastutte's Avatar
thanks, Walt. I went with Brembo rotors and pads. we'll see how they hold up and if i can feel a difference.
Old Mar 27, 2026 | 12:19 PM
Diesel Gypsy's Avatar
I always like to spend $$$ for good rotors but I want soft pads (usually cheap!).
Harder pads, especially metallic or ceramic will last a lot longer but at the expense of braking power.
Old Mar 27, 2026 | 12:20 PM
Old Mar 29, 2026 | 02:11 PM
Tomzsix's Avatar
I like Akebono brake pads . Front and rear . With slotted and drilled rotors .
Old Mar 31, 2026 | 08:49 AM
jastutte's Avatar
worked on the brakes a bit yesterday morning. the fronts were in good shape overall. pads were a bit glazed with some build up at the edges. so pulled them, cleaned them up. the brake material was on the pads was still about 3/8" thick. the rotors were in good shape as well. both calipers had one guide pin each that was not moving. pulled all the guide pins and cleaned them up. i still would have changed the front pads and rotors but the set screw that holds the rotor in place was stripped. so, just cleaned everything up and reinstalled. i have some screw extractors coming and will do everything at a later date.
after cleaning up the front pads and caliper guide pins the Discovery stops more smoothly.
