Recurring P0335 - Crankshaft Position Sensor “A” Circuit
Old Jun 17, 2018 | 03:11 PM
Tim Carruthers's Avatar
4th Gear
Default Recurring P0335 - Crankshaft Position Sensor “A” Circuit
Fellow Disco Owners,
I have an 04 that I’ve been giving a lot of TLC since purchasing 2 years ago. I’ve replaced all the usual mechanicals, sensors, battery, XYZ switch, CPS sensor (last summer), mass air flow sensor and this winter dropped a new engine in from British Atlantic (which is awesome).
I’ve got about 1k miles on it since the new engine. In the last couple of days I’ve had a couple of instances of a bucking and one time the M&S lights came on and she went into limp mode. The bucking only happened under mild acceleration.
Engine and transmission are strong so my thoughts are it’s electrical/sensor related.
What should I do to diagnose this further? Could it be the CPS again? The new one only has about 2k miles on it.
Any help much appreciated.
Tim.
Old Jun 17, 2018 | 06:02 PM
4th Gear
Default More info
I should also add that twice I had to crank the starter for what seemed like a minute before it started. Does this also point to the CPS?
Old Jun 17, 2018 | 06:18 PM
wjsj69's Avatar
Certainly sounds like it. Is your ckps a Bosch? If not, get one; others are unreliable.
Old Jun 18, 2018 | 12:32 AM
JUKE179r's Avatar
I was going to say the same thing.
The Duralast cps I bought at Auto Zone intermittently crapped out on me after 2 months.
Pay the money and replace with a Bosch.
Old Jun 18, 2018 | 07:04 AM
4th Gear
Default Just ordered the CPS original equipment
Thanks for the replies. I just ordered the $90 CPS Bosch original equipment. I checked my order from last year and it was the $60 version.
I’ll report back with results. So looking forward to installing another one of these - not!
Old Jun 18, 2018 | 01:29 PM
mr. choodles's Avatar
Subscribed. Sometimes I have to crank 2x to get her started. She cranks, but no cigar. Happens once in a while with, what I believe, to be a non-BOSCH CPS.
Old Jun 18, 2018 | 02:52 PM
Best4x4's Avatar
90% of the time Duralast units are actually Bosch units. Just ask to look at it before you buy it to verify it.
Old Jul 6, 2018 | 12:03 PM
4th Gear
New CPS in and 100 miles on the clock with no issues. Will report back if I get the recurring bucks.
earlyrover
May 9, 2021 06:08 PM
Richard Gallant
Feb 1, 2019 03:50 PM
robersonb
Jul 20, 2018 11:15 AM
oilspotLR
Jul 24, 2012 11:05 PM
Jake1996D1
Jan 16, 2012 05:48 PM
