Regulator Motor
Regulator Motor
My window stopped working I could hear it trying. So I took it apart, eventually, once I separated the motor from the regulator and plugged in the motor, it worked. It did not work previously, so apparently the wind-y mechanism was binding it up. I put it back together and all is good. It seems the motor itself is dry. Below, is what i am talking about. Can that be lubricated? Or would that mess up the electical motor?
One thing with aftermarket window motors = seal for wiring is crap. I highly recommend using some RTV or silicone where the wires enter the motor. I replaced a 1 year old unit I put in a friend's D2. He said it just quit working. Removed it & found it rusted like the Titanic and the only entry point which I could find = where the wires go into the motor. New one was 27.00
bcolins
10-20-2008 10:52 PM
