Remote entry and starting time out
I wonder if someone might've installed some aftermarket, secondary security system that has a timer incorporated.
Is your keyless entry transmitter the stock style for a DII? How long have you owned the truck?
Have you tried opening a door other than the driver's door to see if that affects the timeout?
I'm wondering if a sensor switch on the driver's door is not letting the alarm system know that the door has been opened.
This is a problem with your passive immobiliser. Using a Nanocom, you go into the alarm settings and disable passive immobiliser. Then once unlocked it stays active to start again until locked.
Can't believe this was such a simple step that nobody (I searched Google also) had the answer too. A local 2nd hand spares shop was able to tell me this immediately when I asked... :P
kman3786
Jan 22, 2009 09:50 PM
