Remote entry and starting time out
Old Jan 1, 2020 | 02:02 PM
Gsknott's Avatar
Thumbs down Remote entry and starting time out
When I unlock disco2 I have to start the vehicle with in 30 second or I have to use the unlock again in order to start. Is this normal
Old Jan 2, 2020 | 08:36 AM
mln01's Avatar
No, not normal. Nor do I recall a setting in the BCU to program that.
Old Jan 2, 2020 | 08:50 AM
JUKE179r's Avatar
That is strangely not normal.
Welcome to the forum.
Old Jan 3, 2020 | 06:44 AM
mln01's Avatar
I wonder if someone might've installed some aftermarket, secondary security system that has a timer incorporated.
Is your keyless entry transmitter the stock style for a DII? How long have you owned the truck?
Old Jan 3, 2020 | 08:34 AM
mollusc's Avatar
Have you tried opening a door other than the driver's door to see if that affects the timeout?
I'm wondering if a sensor switch on the driver's door is not letting the alarm system know that the door has been opened.
Old Feb 16, 2022 | 07:39 AM
douglash's Avatar
3rd Gear
This is a problem with your passive immobiliser. Using a Nanocom, you go into the alarm settings and disable passive immobiliser. Then once unlocked it stays active to start again until locked.
Can't believe this was such a simple step that nobody (I searched Google also) had the answer too. A local 2nd hand spares shop was able to tell me this immediately when I asked... :P
Old Feb 16, 2022 | 09:07 PM
Harvlr's Avatar
Thanks for digging into this one Doug
Evan Wiley
Dec 19, 2012 09:43 PM
Rover_Hokie
May 21, 2012 03:53 PM
kman3786
Jan 22, 2009 09:50 PM
MRDM1
Feb 26, 2007 11:02 PM
angasreid
Oct 22, 2006 11:29 PM
