Remove/disable SAI?
#21
#22
#23
Jafir is right. You need a map sensor in the top of your fuel pump, you need to run 3 wires from the computer to it. Then you need to install a vent valve under hood where the big pipe runs from the dmtl pump. Then you need to wire the vent valve. I have done it and it is easy. For the plugs in the head, the hole in them is a 9mm Allen. You could jb weld a cut off Allen key piece in each of the 4 inserts. You can swap the ecu and bcm out of any 99-02 disco and wouldn't have to program it, but the odometer will blink on and off unless you swap the cluster also.
#24
look for color coding
that "all 4.0s are better blocks" seems to be more of a perpetuated rumor. it may be statistically common, but no evidence supports this. just hear say.
Bryan Siebel
12-09-2011 06:44 PM
