Remove/disable SAI?
Old Dec 3, 2014 | 10:32 PM
  #21
dusty1's Avatar
Originally Posted by 04duxlr
Is a 4.0 an upgrade from a 4.6?
it is if your 4.6 sounds like an early model duramax.
Old Dec 4, 2014 | 05:40 AM
  #22
primussucks's Avatar
4.0 and 4.6 blocks are identical. Except the 4.0 blocks were machined better. I'm moving all my rotating parts and heads from the 4.6 to the 4.0 block. So I will still have a 4.6.
Old Dec 4, 2014 | 08:53 AM
  #23
RoverMasterTech's Avatar
Jafir is right. You need a map sensor in the top of your fuel pump, you need to run 3 wires from the computer to it. Then you need to install a vent valve under hood where the big pipe runs from the dmtl pump. Then you need to wire the vent valve. I have done it and it is easy. For the plugs in the head, the hole in them is a 9mm Allen. You could jb weld a cut off Allen key piece in each of the 4 inserts. You can swap the ecu and bcm out of any 99-02 disco and wouldn't have to program it, but the odometer will blink on and off unless you swap the cluster also.
Old Dec 4, 2014 | 09:06 AM
  #24
dusty1's Avatar
not all 4.0 have better blocks, better tooling.
look for color coding
that "all 4.0s are better blocks" seems to be more of a perpetuated rumor. it may be statistically common, but no evidence supports this. just hear say.
gatorm
Aug 11, 2017 04:04 AM
roverbob
Sep 2, 2012 08:34 PM
uh60driver
Apr 2, 2012 11:22 PM
Bryan Siebel
Dec 9, 2011 06:44 PM
Bryan H
Jul 23, 2010 02:39 PM
